Home > Forums > FLUENT
BOUNDARY_PROFILE UDF
Old   April 16, 2008, 12:52
Default BOUNDARY_PROFILE UDF
Sandilya Garimella
hello
I am writing a UDF to define the inlet bC for compressible flow
The pressure is defined by
p = P_static + 0.5 * density * velocity *velocity
This I am defining in UDF as given below
DEFINE_PROFILE(press,t,i)
face_t f; cell_t c0;
double press; double dens; double vel;
double time=CURRENT_TIME;
begin_f_loop(f,t)
/*c0 = F_C0(f,t);*/
press = F_P(f,t);
dens = F_R(f,t);
vel = F_U(f,t);
if(time<20e-3)
F_PROFILE(f,t,i) = 101325 + 0.5 * dens * vel * vel;
else
F_PROFILE(f,t,i) = 0;
end_f_loop(f,t)
But when I hook the UDF in fluent
I get the following error
ACCESS VIOLATION
Can anyone let me know what is the problem?
Thank you
Old   April 16, 2008, 18:08
Default Re: BOUNDARY_PROFILE UDF
ALI
Hello Sandilya,
May be the compiler you are using might be the problem try to write the code using Microsoft Visual C++ 6.0 or Microsoft Visual C++.Net.
Sometime Earlier i also had the same problem , i tried to check the license and again installed the software (it was on 64-BIT LINUX/UNIX SERVER) but it showed me the same problem then i tried to install it on 32 BIT windows version and it woorked might be this problem for you also.
Just check the code first in those compilers if you are not sucessful in that then go ahead and try the second solution .
Thread Tools
Trackbacks are On
