Fluent not creating Shadow wall
Like Tree1Likes
  • 1 Post By Nick
Old   April 15, 2008, 04:52
Default Fluent not creating Shadow wall
Sanjay Jain
Hi everyone,
I imported the mesh (in FLUENT)of Francis turbine (hydro turbine),which consist of three fluid zones correspond to Casing, runner and draft tube respectively.
But FLUENT does not show any shadow walls between different components, though the mesh of different components are different and not fused with each other.
Please reply me as early as posible.
Thanks in advance.
Old   April 15, 2008, 06:10
Default Re: Fluent not creating Shadow wall
Nick
you will only get a shadow wall if the mesh on a common wall is the same. That is to say if their are two volume zones that are connected and separated by one wall then FLuent will split the wall into two, i.e wall and then its shadow. So the two volume zones each have their own identical wall. You say your mesh is different and "not fused" well you will have seperate walls for the bounds of each of your volume zones and hence their is no need for Fluent to generate a shadow. Bear in mind their will be no heat transfer if this is the case.
Ptegenaw likes this.
Old   April 16, 2008, 08:04
Sanjay Jain
Nick, Thanks for the reply.
As such, in my case heat transfer is not involved.
But there are two static parts(i.e.casing and draft tube)and one rotating part(i.e. runner). Water will enters from casing to runner and then goes to draft tube.
So please...please let me know, whether in this case, generation of shadow walls is required or not.If required then what could be the reason,FLUENT is not generating shadow walls.
Once again thanks in advance.
Old   April 20, 2008, 09:57
Default Re: Thanks...I got the solution
Sanjay Jain
Hi Nick,
Thanks...I got the solution, for why shadow walls were not created?
I found that, FLUENT will create shadow wall only when two different volumes shares the common(single) face. i.e. at the junction between two volumes vertices, edges and faces must be connected but two volumes shall not be merged.
Thanks again.
match uds boundary condition in wall & wall-shadow pour FLUENT 0 May 20, 2008 08:56
Shadow Wall Soheyl FLUENT 1 March 12, 2008 13:45
Fluent Not creating shadow wall Celine Garnier FLUENT 1 September 10, 2007 13:02
wall & wall shadow net heat flux Barbaros FLUENT 1 August 5, 2006 02:00
Fluent creating wall zone on mesh import? Mark FLUENT 4 April 4, 2005 07:14
