April 21, 2008, 05:17 |
Unsteady udf
Hi Dear All I want to define the source term in Energy Equation. After compiling it in Fluent and starting to iteration, this error appears and solver goes out from running mode.This error is for """"C_T_M1(c,t)"""" for taking the temperature value in previous time step.I write this Text Command """""">Solve/set/expert""""" and then answering ""Yes"" to this question""keep temporary solver memory from being freed?"" but my problem has not been solved yet. Please Help me. Best Regards.
#include "udf.h" #define C2 100.0 DEFINE_SOURCE(amir_source4,c,t,dtime,dS,eqn) { real x[ND_ND]; real con, source,delti,al,rol; C_CENTROID(x,c,t); con = C2*0.5*C_R(c,t)*x[1]; al = RP_Get_Real("physical-time-step"); rol=C_T_M1(c,t); source = -.000000001*C_T_G(c,t)[0]*C_T(c,t)*rol; return source; } |
April 22, 2008, 03:20 |
Re: Unsteady udf
instead of RP_Get.... , I would use al=CURRENT_TIMESTEP;
further, I am not sure, but You may need to define a derivation of your source (dS[eqn]) bye |
Unsteady Particle With unsteady Fluid | Ali | FLUENT | 0 | August 4, 2006 11:29 |
UDS UNSTEADY | Arvind Phate | FLUENT | 0 | August 27, 2005 13:17 |
about unsteady | yanghua | Fidelity CFD | 0 | June 10, 2003 20:23 |
Unsteady DPM | Alex Munoz | FLUENT | 0 | May 12, 2003 20:36 |
about unsteady | dahuilang | Phoenics | 0 | November 23, 2001 02:45 |
