April 21, 2008, 05:52 |
Multiphase Eulerian Gas-Solid Flow
Dear All,
I try to simulate gas-solid flow (w/o any reaction) in a 7m-riser with Fluent 6.3 - Eulerian multiphase model (with single solid phase). Air is fed from bottom and solids as side inlets above 0.5 m gas inlet. I have quite a dilute flow (10kg/m2s). Main points of my model: Solver: unsteady (transient) â€" 2D Solution Controls: URFs = Defaults Discretization = First-Order Upwind Granular Temperature Model: Partial Differential Equation Gas-Solid Drag : Gidaspow Viscous model: k-epsilon k-Epsilon model: Realizable / dispersed Near-wall treatment: standard wall functions (No UDFs used for turbulent viscosities) My current mesh with boundary layer is fine enough. 50 elements in radial direction. Time step: 1*10**(-4) max. iter. 30 (slowly increased to this and kept constant) My problem is simulation goes quite well and converges at every time step in the beginning. And particles rise within the riser. After 1-1.5 sec, particles start to get collected near the walls (below 2 m of outlet line). And when it gets dense enough (like a layer/dead zone with a thickness of 20-30 cm), particles suddenly collapse and leave riser from bottom/gas inlet. And I am 100% sure that I am well above choking regime. Unfortunately I couldn't find a solution for this. Does anyone has a similar experience? And any idea how to solve this case? Thanks in advance, |
Multiphase flow (Eulerian) modeling | Umesh | FLUENT | 5 | December 29, 2014 10:06 |
Eulerian-eulerian multiphase modeling | Wee | FLUENT | 3 | May 14, 2008 02:12 |
eulerian multiphase flow(gas-solid) | Masood | FLUENT | 3 | July 29, 2005 04:41 |
enabling UDS in Eulerian-eulerian multiphase model | shao1 | FLUENT | 0 | July 14, 2002 22:23 |
