April 22, 2008, 09:43 |
Help-me GAMBIT
Hi ! I'm trying to mesh a pipe (simple) with gambit but the face is twisted, why? thanks
April 22, 2008, 14:32 |
Re: Help-me GAMBIT
What do you mean by "twisted"?
April 23, 2008, 03:56 |
Re: Help-me GAMBIT
Sorry, but my English is not so good! A part of the meshing of the surface is moved as if it was turned.
April 23, 2008, 03:57 |
Re: Help-me GAMBIT
The lines in the interface are not all parallels
April 23, 2008, 05:05 |
Re: Help-me GAMBIT
Hi
It is hard to tell what the problem is without seeing the mesh. But make sure that you have the same number of nodes for every two parallel lines and the interval size is also the same. Do you have any curved faces? Have you used the Boundary Layer technique for meshing? AAA |
April 23, 2008, 05:18 |
Re: Help-me GAMBIT
thanks for its aid. I am try to mesh a cylinder. The number of nodes and interval size are identical. I did not use the Boundary Layer technique.
April 23, 2008, 05:21 |
Re: Help-me GAMBIT
I presume you are working with 3D now. If so, start by meshing one face, and then use the "Cooper" option to mesh the whole volume. This will give you a better mesh.
Regards AAA |
April 23, 2008, 05:44 |
Re: Help-me GAMBIT
thanks a lot. Now, the problem is when I have the centre section in fluent I appear strange lines in the domain. What is this?
April 23, 2008, 06:13 |
Re: Help-me GAMBIT
#9 |
what type of geometry you tried to plot? is it symetric or no? I suggest the best way for this you plot a simple 2D face then draw the boundary layer and mesh the face with map mesh then sweep the surface to creat the whole volume.
Gambit geometry creation: loading data to gambit | C Ariyaratne | FLUENT | 10 | March 17, 2011 16:39 |
Export data from GAMBIT to GAMBIT | Sanjay Jain | FLUENT | 1 | April 3, 2008 00:44 |
How to Import Gambit 2.2.16 file to Gambit 2.0.0 | solomon | FLUENT | 0 | January 4, 2007 14:49 |
