Parallel UDF
I am getting the following errors with regards to my SEND AND RECV functions: ..\..\src\steady11.c(115) : error C2440: 'function' : cannot convert from 'real' to 'float *' ..\..\src\steady11.c(115) : warning C4024: 'MPT_csend_float' : different types for formal and actual parameter 2 ..\..\src\steady11.c(124) : error C2440: 'function' : cannot convert from 'real' to 'float *' ..\..\src\steady11.c(124) : warning C4024: 'MPT_crecv_float' : different types for formal and actual parameter 2
Any help would be appreciated. #include "udf.h" real inmfr; DEFINE_PROFILE(uvelocity, thread, position) { #if !RP_HOST face_t f; int i,j; real uvel = 0.20; /* meters/sec */ real A[ND_ND]; inmfr = 0.0; begin_f_loop(f, thread) { F_AREA(A, f, thread); inmfr = inmfr + NV_MAG(A); } end_f_loop(f, thread) #endif #if RP_NODE if(! I_AM_NODE_ZERO_P) { PRF_CSEND_REAL(node_zero, inmfr, 1, myid); } #endif #if RP_NODE if(I_AM_NODE_ZERO_P) { compute_node_loop_not_zero(i) { PRF_CRECV_REAL(i, inmfr, 1, i); } } #endif node_to_host_real_1(inmfr); host_to_node_real_1(inmfr); } |
Re: Parallel UDF
Try this:
PRF_CSEND_REAL(node_zero, &inmfr, 1, myid); ------ |
What do you mean, can you tell me more about it? Thank you very much!
