-   -   Importing ANSYS file to FLUENT (http://www.cfd-online.com/Forums/fluent/48051-importing-ansys-file-fluent.html)
Deepak Rammohan April 25, 2008 14:18
Hi Friends,
My name is Deepak Rammohan and I am a graduate student at The Ohio State University in the Department of Aerospace Engineering. I am working on a research project which involves the validation of the frequencies on a plate heated along the edges.
I have obtained my frequencies by doing a modal analysis in ANSYS. However I need to import the file into FLUENT.
When I open the FILE - IMPORT - ANSYS option, the SELECT FILE tab opens up by specifying the file type as a PREP7 file. But ANSYS has the file extension as a .db format, I would like to know how to convert my .db file to a PREP7 format.
I have tried the tfilter command and have used the follwing extension,
tfilter fe2ram -d2 -tANSYS filename.db filename.grd
Even the above approach does not seem to work. Could anyone help me with this situation.
Thanks
Deepak Rammohan
