-   -   Journal files - Batch mode (http://www.cfd-online.com/Forums/fluent/48087-journal-files-batch-mode.html)
Rémi GOULET April 29, 2008 04:43
I make a flow calculation in a simple layout.
But, i need to take the outlet temperature and velocity profiles and use them as inlet profiles for the next calculation (same layout).
I need to repeat this process 70 times.
I know journal files enable to manage this problem.
But i don't know how to construc a loop in scheme programming
Does anybody know it?
Thanks.
mAx April 29, 2008 05:37
Re: Journal files - Batch mode
here on example:
(define start 1) (define ende 9) (do ((n) (i start (+ i 1))) ((= i (+ ende 1)) n) (ti-menu-load-string (format #f "file read-data test000~a.dat yes" i)) (ti-menu-load-string "file read-journal post.jou") (ti-menu-load-string (format #f "display hard-copy test~a.tiff" i)) )
Rémi GOULET April 29, 2008 05:41
Thank you very much mAx, and how can I save results (for example outlet temperature profiles) at each iteration
Thanks for your answer.
mAx April 29, 2008 06:21
File/Write/Profile
Ralf Schmidt April 30, 2008 17:06
hi!
there is a cfd wiki about that:
http://www.cfd-online.com/Wiki/Fluen...ournal_file.3F
hope, it helps Ralf
