Need help with statement in Gambit
Old   May 4, 2008, 07:14
Default Need help with statement in Gambit
kbs
Hey to all I need some help with a phrase not understandable to me mentioned on a paper published on the chemical engineering and processing journal at the year 2006 , the author of the paper said: "The 3D mesh (cylinder) consists of 400 nodes per section with a section every 2 degree, i.e. about 55,000-150,000 eight node brick elements. The prediction where performed with a 40 X 500 mesh. In order to verify the independence of the solution on the mesh size, calculations were also made with a grid of 80 X 1000" The question here : what the author mean with this statement " The prediction where performed with a 40 X 500 mesh" ? how can I do this practically through Gambit? Any idea please?
Thanks a lot kbs
Old   May 5, 2008, 04:28
Default Need some explaining please
kbs
Hello I can send that paper if it necessary just leave a comment please.
Regards kbs
Old   May 6, 2008, 07:18
Default Need some explaining please-urgent paper included
kbs
hey I still not receive any replay about my last question however I was uploaded the paper which I need help with it and all other details about geometry mentioned in page 60 hope somebody can help me and thanks to all. The paper can be downloaded from the link below please cut and paste in your browser: http://www.quickfiles.net/857489
Old   May 7, 2008, 02:53
Default Re: Need some explaining please-urgent paper inclu
bohis
I have read the article. Number1 x Number2 just means the total number of elements in my view. By the way, I do not like their surface mesh on the roll bottom.
good luck
Old   May 7, 2008, 06:13
kbs
hey bohis your answer not understandable? how it mean the total number of elements in your view ? which section you mean (inlet-outlet-wall) and why you not like this mesh in the roll bottom?
Old   May 7, 2008, 06:30
bohis
I mean total number of grid cells in whole cylinder.
I do not like the surface mesh in the bottom of cylinder, since I can see some highly skewed elements (rectangles)
good luck
Old   May 7, 2008, 07:02
kbs
how you know it's a highly skewed elements? did you draw it?
Old   May 7, 2008, 07:10
bohis
I have seen it, you should see it also. The mesh in the bottom is like a rectangular mesh imposed to the circle, thus, there must be naturally highly skewed elements. Understand?
Old   May 7, 2008, 08:20
kbs
well not important if the mesh was bad the important thing is getting good results. Can you tell what the author mean with the mesh consist of 400 nodes per section with a section every 2â-¦? did u know how can this be done?
Old   May 7, 2008, 08:43
bohis
400 nodes mean that there were 400 nodes in the bottom of the cylinder and then it was swept along the length of cylinder. It sounds quite simple. The formulation about 2° seems quite strange to me, however, I thing that it means the sector angle defined by the number of nodes. It means that author had 180 nodes on the perimeter of the cylinder crosssection
Old   May 8, 2008, 02:19
  #11
kbs
hey you mean the interval count equal to 180 for the full diameter hence the angle become 2 degree?
Old   May 8, 2008, 02:34
  #12
bohis
you are right, but I can be wrong, of course.
Old   May 8, 2008, 04:19
  #13
k.baker
everyone can be wrong why you not have confidence in yourself.
Old   May 8, 2008, 04:29
  #14
bohis
okay, so I am absolutely convinced about what I have written
Old   May 8, 2008, 04:50
  #15
k.baker
nobody said that what you wrote is wrong but be aware you may expose to do mistakes through your life.
Old   May 8, 2008, 04:56
  #16
bohis
thank you for your deep philosophical thought. I am well aware of that, since I am making mistakes very often
Old   May 9, 2008, 08:15
  #17
Aris Nikolopoulos
I'm busy too. I'm preparing my next mistake!
GAMBIT Vertex Point Statement asd FLUENT 0 July 12, 2007 01:00
marking statement in Latex mike Main CFD Forum 0 October 8, 2006 12:01
CFX Expression Statement Ivan CFX 3 June 5, 2006 11:42
I fix a problem with DATA statement Soh Siemens 0 May 12, 2006 14:59
Should I use if-statement in a Do-loop? Jongtae Kim Main CFD Forum 5 November 8, 1999 15:10
