How should we calculate the drag force ??
Old   May 3, 2008, 00:40
Default How should we calculate the drag force ??
Thinnapong
Hi All
I have simplae question for the drag force calculation in Fluent, In Fluent can calculate drag coefficient but if we need drag force we should re calculate again right ???
Old   May 3, 2008, 09:20
Default Re: How should we calculate the drag force ??
Zhengwei Long
using UDF?
Old   May 3, 2008, 12:51
Trinnapong
It have another way ?? because I'm not familiars for UDF !!
Old   May 4, 2008, 07:38
m@rk@s
If i am not wrong, you are talking about Drag on body in external flow. In Fluent, Drag and Lift forces are possible to get, Go to Report and then force. There you can select surface on which you want to get forces and given direction (very important). Just say print and it would give forces as pressure and viscous forces which is responsible for total drag forces.
Old   May 4, 2008, 09:21
Trinnapong
Thank for your advice but my simulation is unsteady and need to see force acting on my body for each time step ??? have any more advice ???
Old   May 4, 2008, 13:46
m@rk@s
If you want to know forces on body at each and every timestep, then you can set in Monitor that would give drag at each time step.
How to calculate lift force on equipment in flow Bill MacPherson Main CFD Forum 0 December 30, 2008 09:48
How to calculate the drag force? James CFX 1 April 24, 2008 00:59
how to calculate prssure force & lift force in CFX zaidun CFX 4 March 28, 2006 02:06
Calculate Pressure force andreis FLUENT 0 May 16, 2005 05:40
How calculate drag force for porous sphere Chandan Sarkar FLUENT 2 September 23, 2002 02:12
