March 24, 2015, 05:27 |
high levels of sub-grid viscosity
Rep Power: 15 |
Hi, everyone. Recently, I am working with DES. There are 2 problems that I would like to ask for help here.
First, "very low mesh count for inlet velocity, have the levels of sub-grid viscosity been checked", the question is how can I check the levels of sub-grid viscosity in Fluent? Second, "high levels of sub-grid viscosity could account for the non-turbulent appearance in the wake of the blunt body", the question is what does the high levels of sub-grid viscosity mean? Any feedback is very welcome. Thanks! |
March 25, 2015, 00:14 |
#2 | |
Lucky
Rep Power: 65 |
A high subgrid turbulent viscosity is an indicator that the subgrid scale model is having a large influence on the flow (which can be attributed to mesh being too coarse, i.e. under-resolved DES/LES). |
March 26, 2015, 02:53 |
#3 | |
Rep Power: 15 |
By the way, do I need to refine the mesh in three directions? If that, the total mesh number will increase sharply. Is it OK that I just improve the mesh resolution in the streamwise direction? |
March 26, 2015, 09:34 |
Lucky
Rep Power: 65 |
Because of the way the filter width is calculated (from cell volume), reducing the cell volume will tend to decrease the filter width, so you can refine the grid in any direction to achieve that; but it is still best to refine in all three dimensions and if that is not feasible then refine in direction of strongest gradients. Usually the strongest gradients are normal to the streamwise direction. Unfortunately refining the grid in the streamwise direction will do the least to help you with your problem.
March 27, 2015, 01:01 |
#5 | |
Rep Power: 15 |
March 27, 2015, 19:19 |
#6 | |
Rep Power: 15 |
By the way, in simulations, the grid-independent validation is needed to be carried out, How can I draw the Coarse mesh, Medium mesh and Fine mesh? Is it neccesary to keep the height of the first grid the same near wall surface, and I just reduce/increase the nodes/ratio? Thank you very much! |
Display Modes | |
High curvature 90 degree bend using SST, eddy viscosity drop?? | tinab0binuh | Main CFD Forum | 0 | August 22, 2014 17:26 |
Airfoil grid for turbulent flows: high aspect ratios | Marconi | Main CFD Forum | 1 | September 29, 2012 13:01 |
modelling solids viscosity in eulerian multiphase model | derkaiser | FLUENT | 1 | December 5, 2011 03:42 |
problem: very high turbulent viscosity ratio | Christine Sindelar | FLUENT | 2 | November 9, 2005 07:23 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
