About phase change heat and mass transfer
Old   May 12, 2005, 02:39
Default About phase change heat and mass transfer
Michael
I have been working on the heat and mass transfer simulation on the phase change in a mixing chamber for some time. But I cannot finish it. I do not know how to make use of VOF model to simulate such a problem. As in my idea, the VOF model of Fluent can nearly not be suitable for such a problem. The VOF model can not take account of the mass and heat transfer. For example, you see that, in the 'phase interaction' you could only see the 'mass transfer' bar which I think we may add a UDF about the mass transfer, but in 'heat transfer' bar, nothing!
I have nearly given up my hope! Because I can not get enough materials about the Fluent training. Yes, I am in an University and the University had afforded to buy the Fluent sometime ago but the man who is the administrator would not share the registration with us!
Will somebody lend me a hand?
Old   May 12, 2005, 06:52
Default Re: About phase change heat and mass transfer
edi ghirardi
In Fluent 6.2 you can specify the mass transfer even in the 'phase interaction' panel (it should be a new feature, you could define it via UDF before), but as far as I know you can't customize explicitly a heat transfer between phases in the VOF model, even if you use a UDF...
Good luck
Edi.
Old   February 13, 2011, 01:49
Question
maysmech's Avatar
maysmech is on a distinguished road
How is constant rate mass transfer of Fluent?
Is it for all cells or for cells which had both species?
I mean can it be used for vaporous mechanism?
Regards.
maysmech is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
