-   -   Rotating boundsary ? (http://www.cfd-online.com/Forums/fluent/48399-rotating-boundsary.html)
conan June 3, 2008 05:39
for example, air flows inside a 3D square channel, say x is flow direction, y,z are cross direction,the case is very simple. The channel sits 0.5m from y-axes. Now, I want to study the effect of rotation. The channel is rotating with y-axes, how to set rotating boundary?
if I have set "FLUID, single moving frame, ratating velocity=500rpm, direction(0,1,0)"
For wall, what is the difference in wall boundary between "staionary" and "movingwall,relative to adjacant cell zone, speed=0" ?
for this case, which option should I choose?
thank you
Victor June 6, 2008 06:37
Re: Rotating boundsary ?
I don't think you could using a moving wall BC for the walls in youre duct, as it not symmetric about x axes. I mean, you can set that in Fluent, but you won't have a good solution for your problem.
For solving that, I think you'll have to use some moving mesh models... Not quite easy to set!
Do you really have to use a square channel? Can't you have a cilindric duct? With a cilindric one, you could just do a 2D axisymmetric simulation and that'd be fine.
My best regards, Victor
conan June 6, 2008 18:23
★Re: Rotating boundsary ?
i think you did not catch what i say.
I just need know how to set wall boundary for a rorating passage like gas turbine blade. it is 3D problem. The passage sit away from the coordinate.
wayne June 7, 2008 10:24
Re: ★Re: Rotating boundsary ?
i think it should be wall with rotating speed.for it is no slip wall,with relatie velocity.
Victor June 8, 2008 17:04
I still don't get your problem, but you should just use rotating wall, be sure that you set the right vector for the direciton and for the center of rotation.
You say that x is your flow direction, but it rotates around y ? It's wierd for me...
Curtin University April 6, 2012 00:08
Originally Posted by conan
;151234
thank you
Hi Conan, I know its been awhile since you had this problem. Did you manage to solve... if so how? I'm currently trying to analyse the effect of rotation in channels, however I have not been able to validate my results with an estalished paper, namely 'Heat Transfer in Rotating Passages' by Wagner et al 1991.
Any suggestions?
