Home > Forums > FLUENT
2D XY, Symmetry and Axisymmetry cases
Old   June 3, 2008, 17:35
Default 2D XY, Symmetry and Axisymmetry cases
Gianfranco
Hello I am modeling a compressible flow. The system is a cylinder attached to a pipe. The pipe allows water to come in and since the cylinder is full of water pressure is created. I have 3 different cases XY case in where it is just a plane, Case 2 = XY in where the center BC is a symmetry and Case 3 = Axisymmetry the axis lies in X direction with the domain in the possitive Y direction. The simulation runs ok in the XY case (case 1), in case 2 the simulation runs ok but after reaching 100 MPa in pressure the solution diverges. Case 3 is impossible to initialize the solution the initial values giving by Fluent are 1.#QNAN. I though using case 3 will simplify my problem from a 3D to 2D. At the inlet the BC is mass flow rate of 0.01 kg/s. Does anyone knows why the case 3 and after some iterations case 2 does not work? I have all the files and I would email them per request. Kind regards Gianfranco
Thread Tools
Trackbacks are On
2D axisymmetry Vs non-axisymmetry geometry aPpA FLUENT 4 March 22, 2007 09:33
2d axisymmetry Cote CFX 7 January 12, 2007 11:41
Handling axisymmetry terms on the symmetry line Sonny Main CFD Forum 4 December 9, 2005 17:22
axisymmetry.. again.. queram Main CFD Forum 0 October 18, 2005 08:04
axisymmetry set up for multiple axes of symmetry varghese FLUENT 12 August 19, 2003 07:42
