| subhransu
June 4, 2008 05:38 |
convergence problem in impingement cooling
hello, Am working on a model project involving optimization of different parameters in a jet impingement cooling of a liner(of turbine). I created and meshed the model in icem cfd then imported it to fluent.The model consists of 2 liquid(air) and solid(liner) domain seperately. The impingement is thru a nozzle onto the liner. The temperature on the hotside is 2000F and the inlet air is at 700F. the air enters thru the nozzle(basically a cylinder of dia 1")goes out thru the curved surface (a bigger cylinder of dia 10"). The inlet is velocity inlet with velocity at 200ft/sec. Outlet condn is outflow. turbulence model is kappa-epsilon , realizable with standard wall treatment. The problem is i never get convergence with outlet condn as OUTFLOW, but if it's pressure outlet with no pressure drop then it converges. OUTFLOW is the right boundry condn isn't it. Actually am trying to measure the surface heat transfer coefficient at the impinging surface, pls help thanks for answers
