Turbulent model properties for airfoil
Old   May 24, 2008, 05:34
Default Turbulent model properties for airfoil
Michal
I'm trying to solve in fluent flow around part of wing (dimensions:3x0.3x0.3) in 3D with Spalart-Allmaras turbulence model. On the velocity inlet I set turbulence intensity to 5% and lenght scale to 0.3. There where no problems with convergetion in small attack angle. For higher angles solution don't converge. Where could be a problem?
Regards, Michal
Old   June 6, 2008, 09:59
Default Re: Turbulent model properties for airfoil
Kelvin
Hi Mike,
Separation of flow occured (i.e. stall) for the higher angles of attack and it's no longer a steady flow over the wing?
Good luck.
p.s.: An airfoil is not a wing. Also at higher angles of attack, you might want to try the SST k-w turbulence model.
Airfoil in Stall - Turbulent model. Jack FLUENT 0 November 7, 2008 02:53
Airfoil turbulent separation Seroga Main CFD Forum 0 October 23, 2008 02:02
Turbulent airfoil setup pvtpilot OpenFOAM Running, Solving & CFD 5 July 2, 2007 19:14
simulation of a turbulent flow on airfoil Dante FLUENT 3 June 8, 2007 14:54
Airfoil: Laminar or Turbulent Yap Wen Jiun Main CFD Forum 3 March 12, 2000 11:31
