September 29, 2009, 09:02 |
Dynamic Mesh on Pintle type injector. (Picture and Video Attached)
YH Tan
Rep Power: 17 |
Hi ,
I currently working on a pintle type injector with the shape as below I had tried to create a dynamic mesh model with the Pintle moving down. The fuel flow rate should getting higher and higher together with the pintle move down. In the early few steps, the dynamic mesh was working well, i guess its spring smoothing working, but after a few time step, the mesh fail and get negative volume. what i can guess is the remeshing and layering is failed. I not really familiar with the dynamic mesh setting. I have no idea what mesh should i prepare for this and what dynamic meshing i should be using. Hope there is someone can tell me how this dynamic mesh can be done? Thanks a lot.
Herntan, Add Reputation if I am right Last edited by herntan; September 29, 2009 at 22:17. Reason: add more explaination. |
September 29, 2009, 11:56 |
Video of simulation.
YH Tan
Rep Power: 17 |
Here is the simulation video.
I have small stroke of pintle movement simulation done. But once i move the pintle stroke higher, the simulation fail with negative volume. http://www.youtube.com/watch?v=w-mi5GZgalA
Herntan, Add Reputation if I am right |
September 30, 2009, 01:34 |
Maxime Perelli
Rep Power: 41 |
I am not familiar with smoothing, but I assume it is only available for small displacement.
Smoothing is just a distorsion of your mesh, but there is no remeshing. So you may enable the remeshing option. But in you case I would recommand Layering (add/suppress cell layer)
In memory of my friend Hervé: CFD engineer & freerider |
September 30, 2009, 02:51 |
YH Tan
Rep Power: 17 |
I think i will try to do the layering, thanks for the suggestion.
The simulation should have the injector fully shut off by the pintle head initially. I not able to fully shut it off and it will always leaking initially as in the video. http://www.youtube.com/watch?v=w-mi5GZgalA any idea what technique i can do to make it fully shut off by dynamic mesh?
September 30, 2009, 14:43 |
Maxime Perelli
Rep Power: 41 |
I don't see anything on the video (opening)
Describe the opening you want to modellise (sketch)
September 30, 2009, 21:00 |
YH Tan
Rep Power: 17 |
Max,
Thanks for the reply. Here is the picture of minimum gap that i wish to close. Due to meshing issue, i was never able to close up this gap so there is no fuel flow out before the pintle move down. If u see the video again, u will see there is fuel flow out early in the video without pintle moving down. Here is the video link. http://www.youtube.com/watch?v=w-mi5GZgalA
October 1, 2009, 01:47 |
Maxime Perelli
Rep Power: 41 |
you cannot close properly your gap.
Else you become negative volume If the gap is really axisymmetric, you can use layering and supress cells (gap smaller and smaller) Play with parameters and cell size to resolve the close of your gap. Also if your time step is too big, you won't resolve it properly. But physical closing is (in my sense) impossible because of meshing topoloy
October 1, 2009, 02:01 |
YH Tan
Rep Power: 17 |
Max,
Thanks alot for clearing my doubt. I still wondering if i am stupid for not able to close the gap. The gap is axisymmetric,but its a very small gap ~0.1mm. I will have the simulation start by deactivate the injector zone and once i activate it will together with the pintle movement. This should give a nice mass flow rate graph. Again, Thanks for the reply.
October 1, 2009, 02:44 |
#9 |
Maxime Perelli
Rep Power: 41 |
you can close the gap, but you cannot have contact between your seat and your pintle.
You can exercise yourself by solving it in 2d axy-symmetric, you will fix your problem easier and quicker
October 1, 2009, 02:54 |
#10 |
YH Tan
Rep Power: 17 |
You mean it is possible to have no leak ?
I still wondering if i able to create a gap which Fluent will take it as contact. I need this injector in 3D. I got a non symmetric chamber on my future simulation. I am planning on create mesh for the cone shape cavity which the pintle sitting on. Normally for layering mesh, i will use the extrution with mesh in gambit. It works fine for engine piston movement.
October 1, 2009, 03:07 |
#11 |
Maxime Perelli
Rep Power: 41 |
you can define a no-leak event (define/dynamic mesh/events), but it won't be caused from solid-contact.
you can modify your inlet BC at this special time, so that there is no massflow. But I never did that, so maybe I am wrong...
October 1, 2009, 04:27 |
#12 |
YH Tan
Rep Power: 17 |
The event at dynamic mesh is a very funny thing i found in Fluent.
I was never able to change BC in the event. The best i can do is copy BC in the event. I have no idea how to go around with this but to create a useless BC at somewhere else for it to copy. The choices in the event is very limited. Yes, i can change the pressure inlet become Wall. But i cannot change the Wall become pressure inlet. Do you think there is any technique to switch between pressure-inlet and wall ?
October 1, 2009, 04:51 |
#13 |
Maxime Perelli
Rep Power: 41 |
As I said I have no experience with events, so I cannot answer..
I would try to set the MDM with 2d-axi. If you set the layering properly, you can iterate until there is only one layer in the gap. Only after you will have mesh issue. But if you have 100 layers in your gap, the you can close your gap with a 99.e-3 mm - stroke. If the results are ok, get inspired from it, and switch to 3d
October 1, 2009, 05:03 |
#14 |
YH Tan
Rep Power: 17 |
OK. Thanks Max.
I will post the video here if i successfully done it. Anyhow, i still wish someone can teach me how to use the event in dynamic mesh to switch from wall to pressure inlet.
April 3, 2010, 01:22 |
#15 | |
李逾
Rep Power: 16 |
youtube is unable to log in in my country,would you sent these video to my e-mail. thank for your help |
January 4, 2012, 03:31 |
#16 |
rahgoshafan
Rep Power: 16 |
Hi all
I need help for simulation a pintle injector . can send me project file? thanks |
September 4, 2020, 08:27 |
#17 | |
Mohammad
Im using multiphase with water and air Water with 0.5atm and air with 80m/s Using couple with courant 40 and it's steady flow J.j.jokar1997@gmail.com |
dynamic mesh, pintle type injector |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 36 | January 7, 2015 00:31 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 12:23 |
dynamic mesh and sliding mesh | nasser | FLUENT | 0 | November 1, 2005 02:37 |
