Gambit/Fluent: Fence Porosity - Option?
Old   June 12, 2008, 09:25
Default Gambit/Fluent: Fence Porosity - Option?
Andreas Hornig
Hi there,
I want to simulate the airflow through a fence with a certain porosity, but I want to avaoid constructing it with gambit, because it is very difficlut to get a good quality mesh. Is there some kind of option, so that I can use a line instead and just give thise line the property of beeing this line with the porosity or maximum flow rate through it?
THX in advance,
Andreas
Old   June 12, 2008, 17:05
Default Re: Gambit/Fluent: Fence Porosity - Option?
red lemon
use porous jump.
Old   June 13, 2008, 08:01
Andreas Hornig
hi red lemon,
could you please tell me the path of this menu option? I haven't heard this option and I don't know, where this is in gambit oder fluent.
greets, Andreas
Old   June 13, 2008, 08:29
red lemon
set up the grid in gambit with the fence as an interior zone (facial interior as a connected but shared face). Then change the zone type in fluent to porous jump using the define>bc panel. Then set your loss coefficients. If 3d fx are important then use porous media instead.
Old   June 13, 2008, 17:14
Andreas Hornig
hi and thx for your help. I tried to build the model according to your tips, if I understood them right.
horn.hdtvtotal.com/download/poroustest.zip is that right in concept?(it just a quick test to have a qick result before doing the right model)
do I really have to do 2 seperated faces/areas like shown?
greets, Andreas
Gambit split volume option John peter FLUENT 2 May 2, 2011 22:29
Fence with Porosity, no additional data. How? Andreas Hornig FLUENT 0 September 10, 2008 05:08
How to use blend option in Gambit Sudhir FLUENT 2 September 29, 2007 15:54
How to use boundary layer option in gambit san FLUENT 0 May 5, 2006 00:41
Export option In Gambit krishna FLUENT 9 April 12, 2004 08:04
