Home > Forums > FLUENT
boundry condition problem
Old   June 16, 2008, 18:43
Default boundry condition problem
kamal
hi!
i am new in gambit and fluent.i am modelling fluid and solid heat transfer problem.there is a transfer of heat from cylinder wall to the fluid.this is 2-D problem.what should be the boundry condition for this type of problem??
Old   June 17, 2008, 01:52
Default Re: boundry condition problem
Novice
Bdry condition for the Cylinder wall is--> wall and in the wall panel you can find "thermal" tab. under this one can define the intial condition of the wall like temperature or the heat flux or convection...etc..
hope this helps
Best regards
Old   June 17, 2008, 17:36
chakamal
Hi novice! Thanks for giving me reply...Do i need to take fluid under specify continuum types as a BC's??....
Regards, Kamal
Old   June 18, 2008, 02:35
Farhath
since ur modelling a 2d problem with heat transfer between fluid and solid. To model this in CFD Requirements :
1.You have to specify fluid flow ie... inlet(pressure inlet or velocity inlet..) and outlet(pressure outlet) 2.Thermal parameters at the wall ie...in the wall panel as Novice told ,enter temp ,or heat flux.. 3.no need of seperatly defining any properties for fuid for incompresssible air (default)
hope it soves ur
Thread Tools
Trackbacks are On
Urgent please,Boundry condition raju FLUENT 3 July 29, 2008 05:12
How to model a different boundry condition prateek jain CFX 2 May 24, 2007 06:43
what boundry condition? vaishali FLUENT 0 May 7, 2006 07:27
boundry condition problem arashshahin FLUENT 5 February 16, 2005 10:55
boundry condition moosa Main CFD Forum 0 November 3, 2002 13:09
