Analysis of Hydrodynamic Joural Bearing Using CFD
Old   September 24, 2013, 01:01
Default Analysis of Hydrodynamic Joural Bearing Using CFD
riphaldo
riphaldo is on a distinguished road
Hi all,
I'm presently working on analyzing the motion of hidrodynamic journal bearing using CFD. I have followed the steps that given in the journals written by C.A. Papadopoulos and G. Descombes. However, it appeared that my results are different from their work. Instead of having the negative pressure at the opposite face of positive pressure, the negative pressure just beside the positive. Are there anything wrong with my boundary condition? I used laminar, isothermal, moving mesh for the journal and stationary wall for bearing shell. I also do not have any experience in using UDF to neglect the negative pressure and define the bearing motion. I would really appreciate your help. Thanks
riphaldo is offline   Reply With Quote
Old   October 4, 2013, 10:30
Dinesh
Dinesh_Dhande is on a distinguished road
Can u send me ur case in detail. I am also working on the same and have got the results similar to Papadopoulos papaer ( pattern is same.). Plz pm me.
Dinesh_Dhande is offline   Reply With Quote
Old   October 26, 2013, 15:31
riphaldo
Thank you Dinesh for your response. I have sent you my modeling condition. I hope you can help me out.
Old   October 27, 2013, 17:29
Dinesh
i didn't get ur BC,s. repost it.
Old   October 29, 2013, 23:19
riphaldo
For boundary condition, the journal is defined as moving wall with determined angular velocity, the bearing and side surfaces are defined as stationary wall with constant temperature (300 K). Therefore, the condition of viscosity alteration by the changes of Temperature can be achieved. However, is it possible to set one of the side surface as the pressure outlet and the other side surface as pressure inlet as written by Papadopoulos in his paper? Beacause I still can not reach the convergence if I set the pressure at that both side surfaces with 0 Pa, it just kept saying that there is the reverse flow on the face. How can I fix this?
Old   April 22, 2014, 20:10
Default Ehl
khosro
khosikhan is on a distinguished road
Hi all,
I'm new to Openfoan, and trying to model Elastohydrodynamics condition for point contact. I guess it should be similar to what you've done. Can you please send me your work so I have an idea how to start the modeling. Thanks.
khosikhan is offline   Reply With Quote
bearings, journal, udf, udf and programming, udf code
simulation of a radial hydrodynamic bearing in ANSYS CFX Jalen ANSYS 1 October 4, 2013 10:40
confusion regarding geometry for CFD analysis jeph91 Main CFD Forum 2 June 22, 2013 16:33
CFD analysis assistance required clementlsy Main CFD Forum 5 June 3, 2013 03:32
FDM vs FVM vs FEM in CFD analysis ck5285 FLOW-3D 1 September 1, 2009 10:51
does anyone analysis the hydrodynamic performance? dongtao FLUENT 0 February 26, 2006 09:29
