Home > Forums > FLUENT
Anyone ever use third order? thoughts?
Old   June 20, 2008, 10:09
Default Anyone ever use third order? thoughts?
Paul
I read an article published by someone who said he got good results for efficiency curves of cyclones using third order MUSCL equations. Anybody else use them? Any thoughts/ideas on how to make them converge?
Also, there is no third order option for pressure. Should I just leave it on second order?
Thanks.
Old   June 20, 2008, 10:18
Default Re: Anyone ever use third order? thoughts?
red lemon
yes leave pressure as second order unless PRESTO or QUICK is better depends on your application and mesh. Use MUSCL for all grid types so you can to reduce diffusion but solution may be more difficult to converge and less tolerant of poor cell quality.
Old   June 20, 2008, 12:34
Paul
Yeah I'm having difficulties getting this to converge. Pressure as second order has worked fine for me before so I've left it as is.
The residuals are bouncing around a little but staying somewhat constant. I can tell from the static pressure contour plots however that this thing is nowhere near convergence. I mean I can obviously screw around with the relaxation factors until it finally converges but its not going to give me good data. So far its run for about 15000 iterations on RSM steady.
What I take to be a bad sign is the lack of stabilization of the static pressure of the outlet (which I have plotting while iterating), which tells me that this isn't going anywhere useful.
Any ideas?
Old   June 20, 2008, 14:06
red lemon
15000 iterations is a lot! Sounds like the overall case setup needs checking. Also what is grid quality like ? Ensure first and second order are stable first.
Thread Tools
Trackbacks are On
4th order discretization of 2nd order difference dusky.He Main CFD Forum 3 February 14, 2007 09:00
OpenFOAM: General thoughts?? open Main CFD Forum 5 September 9, 2006 08:08
first order time, second order space sven CFX 1 October 27, 2005 13:05
thoughts on the different companies Jason Main CFD Forum 0 July 13, 2005 20:18
Thoughts about Courant-Friedrich Levy rate Hamm Main CFD Forum 6 June 3, 2004 04:51
