June 24, 2008, 02:19 |
a problem about dynamic mesh
recently I'm doing a simulation about using dynamic mesh,after complieing the UDF function,when I click Load to load the user-defined function library that Ijust compiled,the Fluent told me that : Error: open_udf_library: system didn't find the specified documentation
Error Object: () I don't know which step was wrong pls help me thanks! |
June 24, 2008, 18:11 |
Re: a problem about dynamic mesh
Hi Satum, Well i went through this problem when trying to compile a UDF.
I solved it as follows: First i installed Microsoft Visual Studio 2008 Second i went to My start menu --> Fluent.inc products --> fluent6.1 --> Set environment and accepted to modify environment. Third i opened the microsoft's visual studio command prompt and run fluent from there. Hopefully you UDF will work now. Regards, Wissam Sakr. |
June 25, 2008, 02:37 |
Hi Wissam Sakr, thanks for your suggestion,i have solved this problem thank you
satum |
Display Modes | |
dynamic mesh and udf problem | boboroo | FLUENT | 1 | January 20, 2008 22:26 |
Dynamic mesh problem | Alain | FLUENT | 2 | December 19, 2006 15:46 |
Dynamic Mesh Problem - please help! | Hila | FLUENT | 0 | August 19, 2006 05:19 |
Dynamic Mesh Problem !!!!!!! | CFDtoy | FLUENT | 3 | January 19, 2005 21:17 |
A problem in dynamic mesh | svh | FLUENT | 2 | October 12, 2004 13:50 |
