June 24, 2008, 02:52 |
Centrifugal pump boundary conditions
Hi, I'm trying to simulate a centrifugal pump with 0.5m3/s, 2600RPM, and 15bar pressure rise.My boundary conditions are: Inlet:mass flow inlet, Outlet: 15bar static pressure. But I'm not getting the right pressure at the inlet which is supposed to be 1bar instead of same pressure as outlet. Am I putting the right boundary condition at the outlet or inlet? The fluid is water.
Thanks for any help |
June 24, 2008, 06:19 |
Re: Centrifugal pump boundary conditions
Hi peter how much is ur mass flow inlet value then there is one help file related to centrifugal pump in fluent did u see that......
With regards, Raghu |
June 24, 2008, 20:24 |
Hi Raghu my inlet mass flowrate is 500kg/s or 0.5m3/s. I saw a centrifugal blower tutorial in Fluent tutorial manual but not the pump. May I know which manual pls?
Thanks |
June 25, 2008, 02:02 |
Hi i am also mentioining the same tutorial centrifugal blower ok then can u send ur pressure results.....
June 27, 2008, 17:53 |
Is this MRF or sliding mesh. Have you setup the rotating fluid zone correctly?
June 30, 2008, 05:20 |
I'm using MRF. My rotating fluid zone is correct. But should I set the outlet boundary to be 15bar or 1atm pressure for the design pressure rise of 15bar?
Thanks |
January 5, 2010, 09:59 |
abdul rahman mohd razali
hi,
I'm new to this forum. I'm also doing MRF.. I manage to run and re-model it in 2-D.. I'm trying to convert the MRF tutorial into 3-D for my centrifugal pump project.. Would some one advise me the best way to do it.. Thnaks |
Centrifugal pump | Chetan | CFX | 7 | July 19, 2016 10:58 |
centrifugal pump | rg | CFX | 0 | March 14, 2008 01:59 |
boundary condition impeller centrifugal pump | mino2006 | FLUENT | 2 | December 28, 2006 18:07 |
centrifugal pump and centrifugal fan | Mangesh | Main CFD Forum | 3 | January 3, 2006 11:21 |
centrifugal pump | john | Main CFD Forum | 1 | April 23, 2004 15:54 |
