wing in ground effect
Like Tree1Likes
  • 1 Post By Kelvin
Old   June 30, 2008, 01:10
Default wing in ground effect
meenakshi
i am doing 2D simulations for wing in ground effect in airfoils. Am using naca 4412. no matter what meshing pattern i use, the cl values keep on decreasing with increasing angle of incidence for a particular ground clearance. can somebody help??? it's urgent!!!
Old   July 12, 2008, 13:29
Default Re: wing in ground effect
Kelvin
Hiya,
If I'm not wrong, the WIG effect is due to 3d effects of the wing (i.e. the tip trailing vortices are partially blocked by the ground) and not 2d! So, your analysis would not show the effect in the first place.
Good luck.
hu'hu likes this.
CFD in Ground Effect CFD Newbee FLUENT 1 January 14, 2008 15:27
Ground effect d bull CFX 1 April 12, 2007 08:39
Wing on ground effect John Tong FLUENT 0 September 4, 2006 23:31
Wing in Ground Effect mondal Main CFD Forum 2 June 28, 2006 06:12
Ground Effect & Turbolence Model Stefano Siemens 3 December 17, 2002 06:59
