July 3, 2008, 00:16 |
Free Surface Problem - Convergance
I am running some 2D cases of planing flate plates with an unsteady free surface (air-water) model, using an explicit scheme. This is fine, except that I seem to have to use very small time steps (of the order of 1x10^(-6)) for the solution to converge to residuals of 1x10^(-4) at each time step. The flow velocity is quite high ~ 20 m/s so this is probably to be expected. Since I am not really interested in the transient behaviour of the solution, I beleive it is okay if the residuals do not converge at each time step, as long as they are within reasonable limits. Of the simulations I have run so far, I certainly seem to get unreasonable results when the residuals do not converge sufficiently. What I would like to know is whether there is any other ways of speeding the convergance? I have used implicit body force formulation which seemed to increase the convergance rate somewhat, but am not sure if I could make any other simplifications which might make the solution a bit faster? Thanks Toby |
Display Modes | |
free surface problem | vuthuan | FLUENT | 0 | February 1, 2009 22:00 |
CFX Free Surface problem | sam | CFX | 6 | March 21, 2007 19:49 |
Free surface problem | Luk | CFX | 2 | July 27, 2006 02:07 |
free surface problem PLEASE HELP ME | varshavian | FLUENT | 1 | February 17, 2003 07:07 |
Free surface problem | chang | CFX | 0 | November 13, 2002 12:49 |
