Parallel computing on dual core
Hi all, i would like to know if is possible to launch a parallel computing on a system with a single dual core e6400 processor by assigning one process to each core. Thanks in advance for any answer.
Re: Parallel computing on dual core
Yes you can.
Open command prompt from Visual Studio (if you use Windows) nai then type in the command prompt window: >fluent -t2 and fluent will launch. Then from Fluent Interface go to File-> Run and you will set the number of processes you want to run Fluent. |
but you need 2 licences to do this, on for each process.
Yes! Red Lemon is right!
