Home > Forums > FLUENT
gambit error
Old   July 2, 2008, 09:44
Default gambit error
costy
I'm trying to generate a 3D grid around a hydrofoil. It generate all surface mesh but when I try to generate the mesh on the volume it says that a logical cube cannot be found. What is the that logical cube and how can I fix that error?????
Old   July 3, 2008, 20:39
Default Re: gambit error
Dan
Hi there,
You are trying to mesh with Hex elements. For using hex elements in gambit you need to have a cube. Each surface should exactly map with the surface on the opposite side.
Use tet elements. this should fix your problem.
trying to mesh using Hex elements in gambit is complete waste of time unless the geometry is simple.
Cheers
Dan
Old   July 4, 2008, 02:54
red lemon
a non logical cube is this. Imagine a small circular face that sits inside a large circular face and subtract one from the other to be left with an annular face. This is a non logical cube and gambit cannot mesh it as it is a face made up of 2 edges that don't meet. Splitting the face across into 2 faces of 4 edges each means they are then logical cubes and each can be map meshed.
Old   July 4, 2008, 05:32
costy
Thank you. I don't want to generate unstructured grid (for these gambit has no problem), but I want to use quad and hexa cells. There is another code who can generate grids, and can be imported in fluent??
Old   July 4, 2008, 11:54
red lemon
you can use gambit. just decompose the geometry so it is mappable for hexa.
Old   July 4, 2008, 14:28
red lemon
Old   July 7, 2008, 03:19
costy
I did that. I split the domain in 4 volumes-1 upstream, 1 left , 1 right of the strut and 1 in downstream). The problem is I have 4 faces (2-left and 2-right)inside the domain. When I set the boundary condition I do not consider these 4 faces, but the fluent code considere them some kind of wall, because I obtain wrong results. If I eliminate these faces by uniting the volumes , gambit give me that error with logical cube.
Old   July 8, 2008, 11:31
Micael
Did you define 4 volumes (continuum) in Gambit? You should define only one, selecting your 4 volumes as "Entity".
Old   July 9, 2008, 02:21
costel
Yes, I defined all volumes as 1 fluid entity; my problem is with geometric 4 volumes.
Thread Tools
Trackbacks are On
ERROR IN GAMBIT Anne FLUENT 5 August 25, 2005 04:05
Gambit 2.0 - Error Message (ACIS ERROR 1200) James FLUENT 1 May 14, 2003 08:13
Gambit error david FLUENT 1 October 28, 2002 05:25
GAMBIT error Phil FLUENT 1 March 11, 2002 15:20
error in Gambit Rouham Ganji FLUENT 4 July 18, 2001 10:29
