unstructured or structure mesh?
Old   July 9, 2008, 22:53
Default unstructured or structure mesh?
fadhil
which is better, unstructured or structure mesh? which one can get the result faster and better?
i try to simulate mixing of multiphase flow in the reactor.
thanks in advanced.
Old   July 10, 2008, 01:36
Default Re: unstructured or structure mesh?
zubair
structured mesh. However depends on the complexity of the model one can opt for unstructured domain or zones.
Old   July 10, 2008, 04:08
fadhil
i have try for my case using structured and unstructured mesh. Structured mesh take much longer time to reach the solution rather than unstructured mesh.
Old   July 10, 2008, 15:12
BastiL
How do you define "reach the solution"? In general, as zubair said prefer stuctered meshes over unstructered ones. Very important not just to compare time but also results...
Regards
Old   July 10, 2008, 17:00
red lemon
always use structured mesh except when geometry is too complex and you have to use unstructured/hybrid grid with second order discretisation.
Old   July 14, 2008, 03:12
fadhil
thanks for all.
edge/face based data structure unstructured grid sundeep Main CFD Forum 0 April 25, 2007 12:36
Structure or unstructured mesh Nikos Siemens 2 November 9, 2006 18:35
Structure vs unstructured meshes Des Aubery Main CFD Forum 2 July 25, 2003 23:11
unstructured mesh data structure for FVM J. Kim Main CFD Forum 3 February 17, 2002 02:43
Data Structure for the unstructured finite volume method Anthony Main CFD Forum 4 February 2, 1999 19:24
