time-dependent_velocity
Old   July 3, 2008, 18:30
Default time-dependent_velocity
Abel
Hi, I have a time dependent inlet velocity :
Ux = 100*time, if time < = 4 Ux = 400, otherwise
Please, How to write the correspondant UDF in C language ?
Thanks
Old   July 4, 2008, 03:36
Default Re: time-dependent_velocity
red lemon
this is in the user guide so just copy that format.
Old   July 4, 2008, 04:16
Abel
Hi lemon,
Unfortunately, I have no access to user guide !
Can you please send me the corresponding format ?
Thanks.
Old   July 4, 2008, 11:52
red lemon
heres a udf for mass as a function of time so you should be able to mod for velocity then hook into the bc panel:
/* UDF for setting target mass flow rate in pressure-outlet */
/* at t<0.2 sec the target mass flow rate set to 1.00 kg/s */
/* when t>0.2 sec the target mass flow rate will change to 1.35 kg/s */
#include "udf.h"
DEFINE_PROFILE(tm_pout2, t, nv)
face_t f ;
real flow_time = RP_Get_Real("flow-time");
if (flow_time < 0.2 )
printf("Time = %f sec. \n",flow_time);
printf("Targeted mass-flow rate set at 1.0 kg/s \n");
begin_f_loop(f,t)
F_PROFILE(f,t,nv) = 1.0 ;
end_f_loop(f,t)
else
printf("Targeted mass-flow rate set at 1.35 kg/s \n") ;
begin_f_loop(f,t)
F_PROFILE(f,t,nv) = 1.35 ;
end_f_loop(f,t)
Old   July 9, 2008, 15:41
abel
Well received
thank you Lemon !
Best Regards
Long time CHT transient simulation time step.... JP CFX 0 May 9, 2008 03:36
autosave at flow time with adaptive time stepping Ybes FLUENT 0 November 3, 2007 12:32
local time stepping and pseudo time phil Fidelity CFD 0 February 27, 2006 16:26
Relation of computational time step with real time Salman Main CFD Forum 2 August 3, 2005 14:13
physical time scale.... real time? soubhik CFX 6 November 7, 2003 02:32
