Rendering Fluent Data in Paraview
Old   July 1, 2008, 08:19
Default Rendering Fluent Data in Paraview
burk
hi all
I am testing Paraview 3.2.1 as an alternativ postprocessor for fluent. First results look promising. But when trying to render wall surfaces from fluent (unstructured tetra grid), i get surfaces that looks incomplete or distored. I am sure it is a rendering issue therefore i played around with that options in PV without success so far.
Are there any tips out there?
Thanks Burk
Old   July 1, 2008, 15:52
Default Re: Rendering Fluent Data in Paraview
BastiL
How did you export from Fluent to paraview?
Old   July 1, 2008, 16:26
burk
I exported Fluent dat and cas data to ensight gold format. Then I read the ensigt format in paraview which works fine.
In the mean time I did the same import in paraview 2.6 there the rendering problem did not occur. I copied the default light settings to PV3.2. Now the surface rendering looks fine.
cheers B
Old   July 3, 2008, 15:05
BastiL
Sounds good. Are boundary zones preserved by Ensight import to paraview?
Old   July 7, 2008, 03:32
burk
Yes they are. In PV 2.6 the even the zone names are preserved. In PV 3.* the zone names are substiuted by PV internal numbering. this is a disadvantage for PV 3* to PV 2.6
Fluent -> ParaView Newbie FLUENT 23 September 17, 2021 02:57
From FLUENT data to Paraview bart weisser FLUENT 1 July 16, 2010 04:41
Exporting Fluent vector data into Paraview JT FLUENT 2 December 29, 2008 18:09
[General] Fluent to Paraview Nick ParaView 6 April 16, 2008 11:25
Rendering Rogelio FLUENT 2 November 17, 2005 14:26
