-   -   Wall boundary conditions for 3d-cylinder (http://www.cfd-online.com/Forums/fluent/48707-wall-boundary-conditions-3d-cylinder.html)
Martin Bellmann July 8, 2008 08:55
I defined a simple 3d cylinder geometry in fluent. The wall temperature boundary conditions are defined by profiles T=f(x,y,z). z is the height of the cylinder. Now fluent is interpolating on the basis of a cartesian coordinate system and gives not the right temperature field. The temperature should be the same at the peripheries at the cylinder wall and only vary with the height z. Is there a way to define a 3d cylindrical coordinate system just to interpolate the boundary values in the right way?
umesh javiya July 11, 2008 13:04
Re: Wall boundary conditions for 3d-cylinder
you can also write UDF for defining Temperature profile for boundary condition.....
Both methods are right...as long as ur getting right answer....
