July 10, 2008, 13:16 |
Kolmogorov turbulence time scale
I need to figure out the smallest (Kolmogorov) turbulence time scale of my simulation (unsteady, LES, segregated)
Thee Kolmogorov turbulence time scale is defined by ε and ν ; So I need to find a way to compute the average rate of energy dissipation per unit mass (&epsilon, and kinematic viscosity of the fluid in fluent (&nu ? Thanks in advance! |
July 11, 2008, 13:08 |
Re: Kolmogorov turbulence time scale
May be u could use Custom Field Functions (in define menu) and define your variable... and visualise variable with contours.....
July 15, 2008, 10:04 |
Try writing a UDF for it. Actually its not necessary to reduce to Kolmogorov scales in LES. To work on those small scales you must have Re^(9/4) points in free space. So you must first start with making the mesh very refined. You must have a lot of memory and computing power to work that
Kolmogorov scale .... LES | LESer | Main CFD Forum | 6 | July 3, 2015 06:01 |
Relation between turbulence modeling & time scale? | M. Choi | Main CFD Forum | 0 | September 1, 2005 18:29 |
CALCULATING KOLMOGOROV SCALE | Coln | Main CFD Forum | 0 | January 12, 2004 12:16 |
Kolmogorov scale | T.Misawa | Main CFD Forum | 2 | December 12, 2001 04:02 |
Kolmogorov scale of atmospheric BL | J. Kim | Main CFD Forum | 0 | December 8, 2000 11:45 |
