Home > Forums > FLUENT
viscosity-ratio_transient
Old   July 13, 2008, 04:45
Default viscosity-ratio_transient
Abel
Hi !
The message "viscosity ratio limited to ...." appears when I activate a time dependent problem. It does not appears in the same "steady" problem. The convergence is reached normally in steady case !.
Do you have an idea !
Thanks
Old   July 13, 2008, 06:28
Default Re: viscosity-ratio_transient
Friend
May I suggest one thing that came into mind, that is try the coupled solver instead of segregated and let us know of what happens
Old   July 13, 2008, 17:47
umesh javiya
May be this problem persist for few iterations and will disappear...!! you can reduce time step factor by 100 and try it...and increase it slowly...let say initial time step size about 1e-8 for 10 time-steps and increase to 1e-7 for next 10 time step and so...on.... may be keep at least 100 iterations per time step for initial few time step and see what happen.....
Thread Tools
Trackbacks are On
turbulent viscosity limited to viscosity ratio Elizabeth FLUENT 13 December 16, 2014 09:57
Turbulent viscosity Limited to viscosity ratio Adrian FLUENT 12 September 21, 2011 04:22
Turbulent viscosity limited to viscosity ratio... Cyril FLUENT 8 February 7, 2006 21:34
turbulent viscosity limited to viscosity ratio mukkarum FLUENT 3 May 11, 2004 04:05
turbulent viscosity limited to viscosity ratio of Hua FLUENT 6 April 24, 2003 16:45
