Multiple Dynamic Grid Adaptation
Old   July 8, 2008, 15:36
Default Multiple Dynamic Grid Adaptation
Craig
Is it possible in Fluent to dynamically adapt the grid every time-step based on more than one criteria? For example, is it possible to dynamically adapt the grid based on iso-values of y+ while at the same time adapt it based on gradient-values of pressure? If so, how do you implement this?
It seems that the only place to select the dynamic option is under the adapt-gradient menu. In this menu it only lets you select one adapt scheme.
Thanks,
Craig
Old   July 15, 2008, 23:24
Default Re: Multiple Dynamic Grid Adaptation
Craig
This problem was resolved using the solve execute commands instead of the GUI. When using execute commands, you can specify an arbitrary amount of adapt schemes.
grid partition AND dynamic mesh adaptation !!!!!!! bohis FLUENT 0 January 16, 2009 03:00
Can mesh adaptation be used with dynamic meshing? BillH FLUENT 2 July 22, 2007 16:35
grid adaptation david FLUENT 2 March 23, 2006 18:25
Dynamic grid adaptation vipul jindal Main CFD Forum 2 August 31, 2004 05:22
Grid Adaptation Suresh FLUENT 0 October 15, 2003 13:18
