-   -   A question about Bousinnesq flows (http://www.cfd-online.com/Forums/fluent/48772-question-about-bousinnesq-flows.html)
norris July 14, 2008 13:29
Are boussinesq flows inversible?
For example, if the dimensions and temperature difference was the same, would you get the same flow patterns for a vertical hot plate in a cold room as you would a cold plate in a hot room, only upside-down?
Rakesh Jha August 1, 2008 05:15
Re: A question about Bousinnesq flows
would not the pattern be opposite in the two cases? Apart from dimension and temp diff there is gravity which matters too I believe.
