How Does Fluent Handle Volume Flow in 2D and 3D |
July 15, 2008, 16:20 |
I am running a model in both 2D and 3D with the same X & Y dimensions. After iterations based on a constant pressure or velocity inlet boundary conditions, I observed that the resulting velocity vector plots are similar but the volumetric flow rates at the inlets and outlets are dramatically different. This totally makes sense. But I'm curious as to how exactly FLUENT treats the 2D model. I can't seem to find that information anywhere. Also, can I obtain any scaling factor to convert the 2D flow data into 3D flow data (for faster simulations)? Thanks!
July 15, 2008, 17:37 |
Re: How Does Fluent Handle Volume Flow in 2D and 3
2D geometry is slice for the 3D geometry....
means physically it is assumed that the width is infinite long..... like rectangle channel in 3D can be represented by 2D plane rectangle geometry provided that the width of 3D channel is large enough to consider as not affecting the flow.... |
July 15, 2008, 23:18 |
2D is not infinitly wide. If it was you would have an infinite inlet area and infinite flow rate.
By default, it is unit depth (1 metre) but you can change it in the reference values as far as I can remember. So, to calculate you inlet area it is simply the height*1m depth. If your problem is cyclindrical shape you should use the 2D axisymmetric model. |
July 16, 2008, 02:06 |
sorry..... you are right it is a unit length....
July 16, 2008, 14:38 |
In cylindrical shape isn't the unit depth defined as one radian?
volume fraction in multiphasic flow in fluent | max | FLUENT | 0 | February 16, 2009 08:08 |
How to handle it | ivanyao | OpenFOAM Pre-Processing | 6 | August 24, 2008 21:27 |
impossible for fluent 6 to handle wall functions!? | mike | FLUENT | 0 | November 15, 2006 19:18 |
How to handle peoridic boundary in multiphase flow | Harry | Main CFD Forum | 0 | November 19, 2005 15:10 |
Can Fluent handle species transport in multi-phase | Roger | FLUENT | 1 | January 30, 2003 19:12 |
