saving window as hard copy
Old   July 17, 2008, 22:04
Default saving window as hard copy
Lord Firestorm
Good Day everyone I have several cases to postprocess and i wanted to make it quicker and more effective. That is why i wanted to write a journal. I need to save a picture of the pathlines in a presaved view and save it as jpg. Then a second one diplaying the contours of pressure. And after that some more stuff but less important. I thought i made it write. but.... Fluent is opening the window in the correct view but it doesn't save it properly. I can't open the picture later. And my pressure contours pic is having no pressure it just shows me the boundaries. Here my text commands which i tried to use for doing so: display/path-lines/path-lines velocity-magnitude fan_outlet
2 0 44 n display/view/read-views C:\"view-file" display/view/restore-view "view-file" display/hard-copy C:\"file".jpg y display/contour/pressure -840 850 display/hard-copy C:\"file".jpg y
Thank you a lot for your help
Old   July 21, 2008, 11:07
Default Re: saving window as hard copy
jesse
i have no clue,but, start journa/stop journal, then run it individually for each case seems the easiest way.
Old   July 21, 2008, 21:13
Lord Firestorm
That is no real time saving option.
Old   July 22, 2008, 09:12
jesse
it surely will work by running the program in linux system.
ParaView 330 image saving and image copy ma436 OpenFOAM Bugs 1 February 5, 2009 03:13
hard copy option kiran FLUENT 0 November 20, 2008 01:48
hard copy resolution Gernot FLUENT 3 November 8, 2006 02:44
hard link mesh jojo FLUENT 5 March 15, 2006 15:40
UDS Flux Question - HARD! Greg Perkins FLUENT 1 March 14, 2002 21:54
