July 18, 2008, 15:27 |
reynolds number
Dear friends..i m new in fluent..i need to specify reynolds number but i don't know where to specify that..can anyone help me in that??
Regards, Kamal Chauhan |
July 18, 2008, 18:05 |
Re: reynolds number
Hi Kamal,
What are you modelling? that will help you alot anyway if your model involves rotating element then the speed and the radius of the rotating element as well as the fluid material defines the Renolds number. Rotating Reynolds number = vL/kinematic viscosity, where L is the characteristic length = the radius of the rotating element. That means defining the rotational speed and the geometry as well as the fluid material property leads to specific Re number |
July 20, 2008, 14:05 |
Re: reynolds number
i need to find the Drag co-efficient for reynolds number 20.in my model sphere is inside the pipe and water is flowing through pipe.
July 21, 2008, 05:41 |
Re: reynolds number
fluent code is dimensional...try to set the parameters (velocity, viscosity and so on...) in a way that the product gives you the Re that you need
Display Modes | |
Reynolds number | sisir | FLUENT | 1 | August 18, 2008 13:43 |
Regarding Reynolds number | John | FLUENT | 0 | February 28, 2006 10:49 |
Reynolds number | Joseph | FLUENT | 0 | January 30, 2006 16:40 |
Reynolds number | Mult | Main CFD Forum | 1 | April 12, 2002 12:02 |
reynolds number | Alexis | Main CFD Forum | 2 | December 1, 1999 11:40 |
