July 25, 2008, 13:46 |
Aspect Ratio of 2D model in FLUENT
Hi Gents,
I am currently using FLUENT to model cylinder mounted in a wind tunnel. The model was created and solved in 2D. Now I am wondering whether the Aspect Ratio, i.e. the span of the cylinder would effect the results. So, any idea about the default Aspect Ratio in 2D model, would that be infinite? Thanks a lot |
July 25, 2008, 22:09 |
Re: Aspect Ratio of 2D model in FLUENT
Hi
The "flow dynamics" shouldn't be affected, since Fluent treats the flow around the cylinder as having an infinite length in the depth of the screen. Regarding mass flows and areas etc. though, values per unit length through the screen are provided (goto: Report--> Surface Integrals). Regards AAA |
aspect ratio | boe | CFX | 5 | October 20, 2006 02:13 |
Aspect ratio | Tetra Newbie | CFX | 1 | May 18, 2006 18:46 |
aspect ratio | gorka | Main CFD Forum | 8 | July 14, 2003 04:30 |
aspect ratio | ditto | CFX | 7 | May 11, 2003 11:19 |
Aspect ratio | Gabriel | Main CFD Forum | 7 | January 4, 2000 01:11 |
