information from saved data files:Unsteady flow |
July 18, 2008, 10:09 |
I have saved data flies from a unsteady simulation. There are about 20000 data files from this particular simulation. Now I want to extract information like--temperature contours, velocity vectors, fluctuation at a particular point in my domain and others. To get this information if I have to open all of the data files and get the plots, it will take me forever. Is there any way to automatically extract the information that I need from these saved data files? If there is any script or macro that I can use to do this? Can anyone help me out with this? Thanks and Regards, Atul |
July 18, 2008, 13:10 |
Re: information from saved data files:Unsteady flo
you could your journal file.....for you 20000 files....
July 19, 2008, 03:34 |
Thanks for the response umesh. Can u elaborate more on this? Do u mean that I can create a journal file for this to automatically read all of the data files and get data ?
July 21, 2008, 06:13 |
this is one sample of my journal file which I used long time ago for unsteady simulation..... you may need to prepare like this.... the command for journal file you can find by simply press"ENTER" in fluent tui... more details you could find at following link
http://www.engres.odu.edu/Applicatio.../ug/node48.htm my journal file: for just two set of cas & data file.... rcd bath-unsteady-Re-0.78Re5-case-3--0.085656.dat.gz di set g-s 11 10 9 1 17 14 () /display/set/contours re-g yes di conto press ,, /display/set/hardcopy/color colo /display/set/hardcopy/driver jpeg dis h-c press-%t.jpeg di conto tang ,, dis h-c tang-%t.jpeg di conto r-v ,, dis h-c rad-%t.jpeg di conto a-v ,, dis h-c axial-%t.jpeg rcd bath-unsteady-Re-0.78Re5-case-3--0.085736.dat.gz di set g-s 11 10 9 1 17 14 () /display/set/contours re-g yes di conto press ,, /display/set/hardcopy/color colo /display/set/hardcopy/driver jpeg dis h-c press-%t.jpeg di conto tang ,, dis h-c tang-%t.jpeg di conto r-v ,, dis h-c rad-%t.jpeg di conto a-v ,, dis h-c axial-%t.jpeg |
July 21, 2008, 09:05 |
Dear Umesh, Thanks a lot for information. I will look into it and figure out how to use it for my case. Thanks again for help. Atul
July 27, 2008, 20:05 |
Thanks for the information umesh. Are you writing these commands repetitively for all of the data files in your journal file?
[OpenFOAM] Saved DATA doesnt have Patch Names | velan | ParaView | 0 | January 9, 2009 07:32 |
Getting Time Series data from saved unsteady data | Atul | FLUENT | 4 | November 26, 2008 05:12 |
Unable to open saved files in DesignModeler. | Tony | CFX | 0 | June 18, 2007 13:20 |
reading saved case and data | maxime henno | FLUENT | 1 | June 12, 2007 06:40 |
very large saved files | jelle | Phoenics | 4 | August 5, 2005 08:49 |
