udf variable for wall temperature
Old   July 31, 2008, 08:31
Default udf variable for wall temperature
Kiran
Hi , I am Using UDF to report wall temperature.
For which I am using variable F_T to get the data.
Till now it is fine , and I am able to get metal surface temperature.
Now I am Defining an insulation layer on the surface by applying thickness in fluent wall BC panel.
So I am getting two different temperatures on metal surface i.e wall temperature (inner surface and outer surface).
I need to report both the temperatures by udf.
For that I need corresponding variable names for wall outer and inner surface temperatures.
Thanks
Kiran
Variable temperature wall boundary condition Virginie FLUENT 2 October 2, 2007 09:23
temperature of additional variable fintan Main CFD Forum 0 December 20, 2005 10:02
Variable temperature BC Paul FLUENT 0 August 27, 2003 13:18
About fix wall temperature in wall boundary joon Siemens 2 March 10, 2003 01:41
Variable wall velocity Sambasivam FLUENT 2 November 21, 2001 22:23
