udf variable for wall temperature
Hi , I am Using UDF to report wall temperature.
For which I am using variable F_T to get the data. Till now it is fine , and I am able to get metal surface temperature. Now I am Defining an insulation layer on the surface by applying thickness in fluent wall BC panel. So I am getting two different temperatures on metal surface i.e wall temperature (inner surface and outer surface). I need to report both the temperatures by udf. For that I need corresponding variable names for wall outer and inner surface temperatures. Thanks Kiran |
