August 11, 2008, 08:22 |
Unstead vs Steady for VOF
Hi all!
I am simulating the free surface by using VOF model for 3D, however I face a problem is: From Initial, running with Steady, the solution gives a error. Meanwhile, running with Unsteady is smooth solution. When I switch from Unsteady into Steady, the Continuity Residual is very high (More than 0). Everyone can suggest for me the reason and how to solve this, because I need Steady solution to check result quickly. Thank you all! |
August 11, 2008, 08:41 |
Re: Unstead vs Steady for VOF
It is recommended to run VOF model only in unsteady state since it involves tracking of the interface with every timestep. Steady state VOF solution has very little significance. To obtain a steady state solution, you can run an unsteady problem till you reach steady state.
steady + unsteady | Kostas Pan | Main CFD Forum | 0 | March 10, 2009 17:40 |
How to determine whether flow is steady or unstead | Maliya,Barth | Main CFD Forum | 7 | October 7, 2006 02:26 |
Steady LES? | GER | Main CFD Forum | 3 | May 12, 2005 14:37 |
Can sb know the analytical solution for 2d unstead | ppaitt | Main CFD Forum | 2 | September 20, 2004 04:04 |
BFS: steady? | Jan Ramboer | Main CFD Forum | 1 | September 9, 1999 14:04 |
