pressure with velocity inlet boundary conditions
Old   August 4, 2008, 06:24
Default pressure with velocity inlet boundary conditions
Ashraf Sharara
Hi
I want to simulate the water flow through a globe control valve. The experimental measurements gave me the values of pressure at the inlet and outlet of the valve. Moreover, the water mass flow rates are also measured during the experiments. The problem is:
With the incompressible flow (water) how to specify the correct pressure at the velocity inlet boundary condition?
Note:
Pressure inlet BC gave me correct pressure and wrong mass flow rate
Velocity inlet BC gave me correct mass flow rate and wrong pressure values
Please help and many thanks for all
Old   August 21, 2008, 07:29
Default Re: pressure with velocity inlet boundary conditio
j.sureshkumar
velocity inlet bc is correct one
Pressure inlet boundary conditions for open channel flows jack2000 OpenFOAM Running, Solving & CFD 5 December 6, 2018 11:00
Velocity inlet boundary conditions abm FLUENT 16 October 18, 2014 08:52
velocity inlet vs pressure inlet cheong FLUENT 6 April 9, 2011 03:07
Velocity Inlet Boundary Conditions katy FLUENT 2 January 5, 2006 15:35
Velocity Inlet Boundary Conditions M.A. Rakib FLUENT 3 June 7, 2000 09:40
