-   -   no-slip problem (http://www.cfd-online.com/Forums/fluent/48996-no-slip-problem.html)
corenc August 12, 2008 02:14
no-slip problem
It's my first test of fluent but let me feel very frustated.
Firstly, I give the settings : geometry: a simple 2d channel left/right boundaries are velocity inlet/outlet flow bottom/top boundaries are wall Materials: water fluid
The problem is: when I set the wall as no-slip and viscous->laminar, I can't find the simulated velocity field has gradient in the normal direction of the wall, and he velocity at boundaries are not zero. The result is nearly the same when I set viscous to "inviside"
Why?
Thanks in advance.
corenc August 25, 2008 23:21
Re: no-slip problem
please HELP me thanks
