Home > Forums > FLUENT
Pressure BC
Old   August 13, 2008, 03:42
Default Pressure BC
giacomo
Hi all, I have a question on defining rightly the pressure term for a pressure outlet boundary condition. I am modeling natural convection within an enclosure with free openings to the outside. When I am asked to enter the ambient ( = outside the domain) pressure should I enter the hydrostatic head ( = - (density * g * opening height)) or this is not required as it is computed automatically by the software. Any help will be appreciated, Thanks in advance,
Giacomo
Old   August 13, 2008, 06:40
Default Re: Pressure BC
ravi
hi,
u can give 0 gauge pressure at outlet wen the flow is going to atmosphere. at the same time u have to give pressure inlet B.C give boussinesq law for density variation in material panel. use body force weighted for pressure equation.
Old   August 19, 2008, 07:32
j.sureshkumar
hello giacomo
the reply by ravi to your problem is good one if you want to find the pressure drop you can give zero gauge pressure.and at the inlet you can specify the velocity inlet
Thread Tools
Trackbacks are On
What type of pressure can give the pressure drop david FLUENT 1 February 17, 2014 12:51
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 18:20
Forcing pressure outlet according to pressure prob Cedric FLUENT 0 July 29, 2005 11:49
pressure driven flow by pressure correction method justentered Main CFD Forum 0 December 30, 2003 00:52
Total pressure to static pressure ratio roadracer CD-adapco 1 April 17, 2003 05:31
