-   -   DEFINE_INIT PROBLEM (http://www.cfd-online.com/Forums/fluent/49011-define_init-problem.html)
Craig August 13, 2008 18:11
DEFINE_INIT PROBLEM
/* This function initializes my domain on the left side with species 0 at 300K and species 1 at 600K on the right side. domain is 1 meter long */
#include "udf.h"
DEFINE_INIT(my_init_function,d) { cell_t c; Thread *t; real xc[ND_ND];
thread_loop_c(t,d) {
begin_c_loop_all (c,t)
C_CENTROID(xc,c,t);
if (xc[0] < 0.5)
C_T(c,t) = 300.;
C_YI(c,t,0) = 0.;
else
C_T(c,t) = 600.;
C_YI(c,t,0) = 1.;
end_c_loop_all(c,t) } }
Craig August 13, 2008 18:16
DEFINE_INIT PROBLEM DESCRIPTION
The above UDF compiles and runs when hooked. The temperature on the left is 300K and the temp on the right is 600K. Species 0 is on the left and Species 1 is on the right.
However, when i zoom into the walls on the right side, the wall nodes appear to be initialized with Species 0.
I think that I need to add an f_loop to initialize nodes on the wall but the temperature loop seemed to work fine. Any ideas?
Smith_K August 14, 2008 01:28
Re: DEFINE_INIT PROBLEM DESCRIPTION
Assign the species mass fraction in the wall boundary conditions. By default the mass fraction of all the species will be zero. You do not need a UDF to assign the same on the walls. Regards,
Craig August 14, 2008 17:34
Thanks for the response.
My wall boundary is set to: Zero Diffusive Flux for species and 0 Heat Flux for Temp. So, my wall species and Temp is allowed to float based on what happens in the interior.
When I initialize the domain to one temp and species without the UDF using solve/initialize I see that all interior nodes and wall nodes are at the initialized species and temperature.
When I initialize the domain using my UDF I find that only the interior nodes are properly initialized (because I have only looped on cell centroids).
Since I don't want to specify species or temp as a boundary condition, I believe that I must do something extra with my UDF to initialize the remaining part of my domain that my begin_c_loop missed.
Thanks again.
