August 13, 2008, 22:39 |
Comparing convection and diffusion in fluent
Just wondering if anyone can help with this... I've got two streams separated by a solid. To reach the solid boundary, the bulk channel flow must pass through a porous region. I'd like to compare the solutions when Navier-Stokes is solved normally to that when the transport in the porous region is by mass diffusion only. The channel flow will is is solved by Navier-Stokes in both cases... I'd be greatful for any input on how to implement this. I've tried setting the velocity values in the porous regions to zero, but I get an erroneous, albeit stable, solution. Anyone have any ideas out there? Thanks, Emmanuel |
Convection, diffusion and reaction | Joao | CFX | 0 | October 25, 2008 20:19 |
Analyzing Convection vs. Diffusion | Emmanuel Resch | Siemens | 3 | March 27, 2008 14:55 |
nonlinear convection-diffusion | Abhijit | Main CFD Forum | 1 | February 26, 2007 05:51 |
convection dominated convection-diffusion problem | Kang, S. K. | Main CFD Forum | 0 | December 22, 2000 14:25 |
Diffusion / convection | I. Dotsikas | Main CFD Forum | 2 | April 21, 1999 16:39 |
