wind tunnel simulation
Old   August 14, 2008, 20:00
Default wind tunnel simulation
Andres Paez
I am trying to simulate the flow of a closed circuit wind tunnel in Fluent but the results are not making sense. I am running the simulation in 2ddp.
I modeled the fan section by cutting the tunnel and having two boundaries. For the boundary that corresponds to the fan outlet I assigned velocity inlet, and for the boundary that corresponds to the fan inlet I chose outflow. Could anybody let me know wich boundary conditions should I assign to the boundaries representing the fan inlet and fan outlet. Any suggestions about an adequate viscous model?
Thanks a lot !
Old   August 15, 2008, 00:17
Default Re: wind tunnel simulation
Raju Ramaiah
Hi, try with Pressure Inlet and outlet combination,since fan is a momentum source, u can try this. Raju Ramaiah
wind tunnel and simulation results different richard FLUENT 2 February 14, 2012 08:06
Push/Pull blower simulation, open wind tunnel Roland CFX 3 February 20, 2008 16:42
CFD in wind tunnel Anders Hagberg Main CFD Forum 9 June 1, 2004 17:42
Flow pass a group of building:Wind tunnel test vs. CFD simulation Tomb Main CFD Forum 7 June 15, 2000 09:27
A conference in air load /flight simulation/flight test/wind tunnel test/aero modeling for high AOA cimsi Main CFD Forum 0 September 17, 1998 06:26
