Pressure profile UDF for unsteady-state problem? |
August 19, 2008, 10:01 |
Dear Sir I would like to write a UDF for a pressure inlet profile in an unsteady-state problem. I mean the pressure varies with time and also the pressure curve equation changes 2 times in the period. I have studied the UDF manual, but there was no UDF about time varying problem. Would you please help me? Thanks.
August 19, 2008, 14:05 |
Re: Pressure profile UDF for unsteady-state proble
There is a tutorial problem with time varying velocity... please see if that helps...
Google search could also provide you some information... http://web.njit.edu/topics/Prog_Lang...ml/node112.htm |
August 20, 2008, 04:22 |
Dear AJ Thanks for your great favor. But I have more questions: 1. May I use that for 3D models? 2. How can I change the equation during time? (Maybe I should use some if ... else statements)
unsteady pressure, temp profile without a udf | mahi | FLUENT | 0 | November 10, 2008 03:53 |
unsteady state velocity problem | Vedavyasa M | FLUENT | 0 | June 28, 2007 06:33 |
How to set to unsteady state | Cynthia | FLUENT | 0 | April 10, 2007 05:27 |
unsteady state problem | prasad | FLUENT | 0 | April 4, 2002 22:44 |
Unsteady state modelling | Mehul Kinariwala | FLUENT | 3 | September 1, 2000 09:58 |
